AE92 FXGT suspension...?
Postby lucasthefallen » Sat Aug 25, 2007 7:19 pm
car is a 1991 smallport fxgt ae92.
at this point in time looking to renew shocks and upgrade springs. any advice or personal expirences welcome. is there a TRD spring set available??
car will be sitting on 15" rims at some stage ( currently 14 ).
also considering a nolathane bush kit ( or something of the like ) are there ready made kits i can buy off the shelf, if so where???
budget around $700-$1000.
car is a daily driver, just want something thats handles better, looks better.
thanks!
Need Service or Repair work done? send me a PM
lucasthefallen
Postby deaf_rattle » Sat Aug 25, 2007 7:27 pm
buy a kit from Barry
i would if i could afford to :cry:
Postby Cakky » Sat Aug 25, 2007 11:31 pm
trd springs are not available for the ae92 series, however trd shocks are available, probably for that budget best to go with a king/trd combo. if you want to fork out more look at a rear sway bar as well..
1989 Corolla GT sedan blacktop 20v
Cakky
Postby lucasthefallen » Sun Aug 26, 2007 12:21 am
deaf_rattle wrote:buy a kit from Barry
.... barry?
lucasthefallen
Postby deaf_rattle » Sun Aug 26, 2007 12:22 am
Postby lucasthefallen » Sun Aug 26, 2007 12:23 am
Cakky wrote:trd springs are not available for the ae92 series, however trd shocks are available, probably for that budget best to go with a king/trd combo. if you want to fork out more look at a rear sway bar as well..
mmm, so front and rear trd shocks are available? are they very pricey?
how do tein springs compare to other brands? are they even available?
i dont want to use king springs, have heard bad things
lucasthefallen
ah i see, not really after adjustables, i'll get too carried away i think lol
lucasthefallen
Postby Mr Revhead » Sun Aug 26, 2007 1:12 am
Cakky wrote:best to go with a king/trd combo.
dont you dare.
go TEIN
Postby lucasthefallen » Sun Aug 26, 2007 9:02 am
and while im at it, i'll be getting some 15x6.5" wheels, whats the desired offset i need to order??
( will be using 195/50/15 tyres, more then likely a set of re001's )
lucasthefallen
Postby rollaholic » Sun Aug 26, 2007 9:36 am
call chris at centrelign / autolign in grey lynn
they are tein agents and hes pretty switched on when it comes to suspension.
Postby lucasthefallen » Tue Aug 28, 2007 8:09 pm
well i looked into parts etc further. have ordered some dobisport 30mm lowering springs and some KYB shocks all round, setting me back $710 ( not retail ) which i'm pretty pleased with.
i enquired about tein springs, and was told that they didnt make them.
i also chose the 30mm dobisports over the 40mm or 50mm varients.
now on the look out for a nolathane bush kit, and possibly replacing the tophats as well.
everything will be done in a few weeks or so, i'll put pictures up with other stuff in the Projects area!
lucasthefallen
Postby Ae92typeX » Tue Aug 28, 2007 8:18 pm
Got my Ae92 nolathane set from wairau suspension afew years ago. had it all off the shelf.
Ae92typeX
Postby lucasthefallen » Wed Aug 29, 2007 8:32 am
Ae92typeX wrote:Got my Ae92 nolathane set from wairau suspension afew years ago. had it all off the shelf.
great! thats just down from work, will look into, thanks alot!
lucasthefallen
