i used to use gasket goo on everything even if i had the correct gasket, as sort of a just to be safe thing. I never had any major issues before. someone mentioned to me that if you have the correct gasket you shouldnt have any issues and not require goo.
this time around i have reassembled everything with the correct gaskets minus goo, mainly only because i couldnt find my caulking gun.
what do most people do? especially when assembling things like manifolds, turbos etc?
