16v 4age sumps - rwd vs fwd
Postby l1ttle_d3vil » Sat Sep 01, 2007 10:07 pm
I've seen a few sumps advertised as "genuine rwd 4age sump, a must for a rwd 4age conversion" etc etc. are they actually any different to fwd sumps?
i'm looking at fitting oil return lines to a spare bluetop sump i've got, with the intention of eventually putting it on my aw11 4agze block - problem is I can't pull the 4agze sump off yet so can't compare.
am I going to run into any problems when fitting the bluetop sump (whether its fwd or rwd) onto the aw11 block??
cheers.
-matt
Postby frost » Sat Sep 01, 2007 11:56 pm
no you wont have any problems , the only difference between them is on the sloping pan part going into the bowl is the ridges face different ways,
Postby Stealer Of Souls » Mon Sep 03, 2007 12:47 pm
I think the sump nut is on different sides too.... But that doesn't actually impact on anything that I'm aware of.
'86 AE85.5 Levin
Stealer Of Souls
