20v Head tool
20v Head tool
Postby Zyros » Sun Sep 02, 2007 7:22 pm
I have read the FAQ on it, but it doesnt say what is the correct tool, its just saying heaps of tools you could use..
Anyway, removing the head on my 20v silvertop, and my mate said he can get me the tool through repco for cheap.
So can anyone tell me the exact name of it, i have a T55.. but i dont think thats it?
Zyros
Postby matt dunn » Sun Sep 02, 2007 8:55 pm
It's not a T50 or a T55. They are torx bits.
The proper tool is a 12 spline head stud tool
Postby AceSniper » Sun Sep 02, 2007 10:08 pm
2nd that I got a set of 4 for around $8
AceSniper
Postby TRD_ZERO » Sun Sep 02, 2007 10:21 pm
Where did you get that deal from?
TRD_ZERO
Postby Mr Revhead » Sun Sep 02, 2007 10:23 pm
http://forums.toyspeed.org.nz/viewtopic.php?t=38883
the koken tool is perfect.
iv also got some powerbuilt bits that fit
Postby AceSniper » Sun Sep 02, 2007 11:19 pm
extremeautomotive ham, was a cheaper set but worked fine.
powerbuilt also do a set of 4 for around the $20? mark try tool shed for them
Think its the 12mm spline that fits
AceSniper
Postby 85AW20v » Mon Sep 03, 2007 11:23 pm
You can get the bolts undone with an Allen key of the right size as they're basically six point. You can also get hex drive sockets to torque it up again which you can then use for cap screws so then you havent got a single use once in 200,000km tool .
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Tue Sep 04, 2007 12:32 am
I'd rather spend the money and buy the right good quality tool so i know that when I torque the head, it done to the right spec's and there is no allowance for the allen key or torx bit twisting in the splines,
In fact, I have two of them, both koken ones.
And have used them probably 20 times now putting heads on and off,
but then I do more 20V stuffing around than most.
Postby Mr Revhead » Tue Sep 04, 2007 10:23 am
yeah mines had good use too!!
Postby Dell'Orto » Tue Sep 04, 2007 12:22 pm
Besides, the Koken tool is only like $28 or something....if you can't afford to invest that in a tool then you oughtnt be fiddling with cars 8)
