Refreshing engine after Blown HG
Postby AE86less » Tue Sep 04, 2007 11:29 am
I picked up and ae82 fxgt yesterday from hamilton for $200. :lol:
It has a blown head gasket and a poked clutch :cry:
I have not dealt with a blown HG before and i want to know what i need to do to get the engine running primo again. I tried to start it yesterday and it was turning over fine but not firing, i'm pretty sure that it should still run? Anyway, once ive replaced the gasket, what needs doing?
Also, does anyone have any idea why the key might suddenly stop turning in the ignition? I took it out and now it wont turn.
I have tried looking for answers on the interweb, but everything assumes that i am not so n00bish..
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Dell'Orto » Tue Sep 04, 2007 12:20 pm
Have the head checked to ensure it hasn't warped, otherwise it'll blow again within a short space of time. Good time to check all the valve guides and stem seals too.
As long as it didnt get too hot when it blew it ought to be ok...if it did, then the rings can get naffed as well.
Postby Trls250s » Tue Sep 04, 2007 12:22 pm
Your question about the head was just answered.
With regards to the key, sounds like the key is warn and isnt lifting all the lugs in the ignition barrel. Same deal with my car, just get the key recut for $3 from a key cutter and it should fix that problem.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby AE86less » Tue Sep 04, 2007 12:25 pm
I'm not expecting the engine to be in great nick after 291 000kms anyway. I asked because all the plugs etc seem to be covered in carbon deposits... :? Looks like i need a replacement!
Cheers for the tip with the key, i did notice it was very worn.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby crazed_silvertop » Tue Sep 04, 2007 1:17 pm
you havent got the steering lock on have you? like turned the steering wheel until it locks.... if you have you need to turn the wheel a little bit then turn the key :)
Just thought i'd point out the obvious...
'89 MR2 AW11 - Silvertop..... fun :)
crazed_silvertop
Postby AE86less » Tue Sep 04, 2007 4:36 pm
Nope, i accidently put the steering lock on after i couldn't turn the key :P
I think i must've broken something in the lock, the new key opens the boot just fine, but doesn't turn in the ignition
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby AceSniper » Tue Sep 04, 2007 5:20 pm
spray some crc down it and slide the key in and out afew times, something might be abit sticky?
AceSniper
Postby Mr.Phreak » Tue Sep 04, 2007 5:24 pm
Don't use CRC or WD40 etc......Use graphite
Mr.Phreak
Postby AE86less » Tue Sep 04, 2007 5:39 pm
:? already used WD40.
I went to show my dad the problem and the key refused to turn in the boot as well, after feeling 100% fine before.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby try_hard » Tue Sep 04, 2007 5:47 pm
i had the same prob with my car with the key. my key was so worn it wouldnt work i tok out the drivers side lock and took that to beggs security and they cut a new one. was longer and had more volume than the original. worked first pop[/code]
AE92 Trueno Sprinter 4AGZE
try_hard
Postby AE86less » Tue Sep 04, 2007 6:12 pm
Lol, someone has mulched both of the door locks with a screwdriver on mine :lol: . I think i might just go to Pickapart and get a whole new set.
Trouble is that this is stopping me from getting anything done on the engine :x
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby AceSniper » Tue Sep 04, 2007 8:22 pm
unbolt it and cross afew wires :twisted:
AceSniper
Postby Infinite » Tue Sep 04, 2007 10:14 pm
doesnt the rear part unscrew and u can turn it with a flat head?
Lots
Infinite
Postby AE86less » Tue Sep 04, 2007 10:28 pm
I wouldn't know? Can you do that even with the wheel/steering lock on?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Trls250s » Tue Sep 04, 2007 10:40 pm
You have to break the ignition. Those barrels taperd in and the mounting screws thread themselves when u install them. Youd need one of those pulleds like the car thieves use, or else remove your steering wheel and slide the whole ignition assembly off.
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Infinite » Wed Sep 05, 2007 8:18 am
on the back of my toyota u can unscrew the part that the wires go into and then u can turn that with a screw driver duno if u have that on a fxgt tho id imagen u do tho, should be 2 little gold posie screws at the back...
Lots
Infinite
Postby AE86less » Wed Sep 05, 2007 10:52 am
Cheers mate, will have a look when i get home from uni.
How much should i expect to pay for a clutch kit? Theres a guy on TM who reckons he can get a TGP one for $160, i'd prefer to buy that and the HG from warwick but i need them asap and he hasn't got back to me...
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Users browsing this forum: Google [Bot] and 25 guests
