Zak wrote:Buy keeper springs, that center bolt needs to be tight at all times.
Mattly104 wrote:can you not adjust the strut length by unbolting the bottom bit off the hub and turning that?.
IM not sure i can have a look. DO you mean spin the bottom of the strut clockwise so that it goes up? Would it do that? If that is the case i might just leave it, that super strut is a pain in the ar*e all thes arms and bots. Good luck spinning it there with all that crap in tha way
