Kender wrote:According to Toyotas TRD website, the gearbox in an '89-'92 SW20 3SGTE requires a different LSD part number to that in a '92-> SW20 3SGTE.
Are there any other differences between the 2 gearboxes, and are the 2 interchangeable?
fivebob wrote:The housings are not interchangeable, the gearboxes are, provided you also change the axles as well
Kender wrote:fivebob wrote:The housings are not interchangeable, the gearboxes are, provided you also change the axles as well
What is the difference in the axles? Is it just the diameter of the shaft (phraw, that sounds rude) or are the inner cvs different as well?
92mr2paddy wrote:man thats confusing,
so the gen2 turbo axles splines are longer than the gen3 ones meaning that the gen2 axles wont fit with the gen3 box???
huh?
