Ok, searched a bit last night but only found stuff on using a 1s sump ect ect, I have a 3sGE block with a gen 2 3sgte head and turbo off the side. what has to be done to the sump and oil pickup? when i stand the motor up right. by upright the cam cover is flat inline with the strut towers...
Also had a look at removing the dizzy and going to sensor/coil packs but only found one post? and had mentioned in it using the dizzy head as the sensor could anyone please give me more insight on this? the 3sfe had coil pack ignition? but were is the senser? pictures would be great if not to much trouble, there is 2 wires going to behind the crank pulley is this a crank angel sensor?
thanks!
