castrol edge 25w-50
castrol edge 25w-50
Postby LEV_101 » Sat Sep 15, 2007 4:23 pm
hi all,
could someone tell me if this is suitable for my mr2 3sgte ?
as i put some in and then i turned it on and 5 mins later it started to blow white smoke out.
thank you
LEV_101
Postby Lloyd » Sat Sep 15, 2007 4:43 pm
Little bit thick for a modern turbo engine. What made you put that it in?
Postby LEV_101 » Sat Sep 15, 2007 6:35 pm
HRT wrote:Little bit thick for a modern turbo engine. What made you put that it in?
shouldnt turbo cars use thicker oil ?
its the first gen sw20 ?
is there a problem why its blowing out white smoke ?
LEV_101
Postby flygt4 » Sat Sep 15, 2007 6:41 pm
a 15/40 would probly be more suitable.
i put a 25/something in my old mitsi before i sold it to shut the lifters up :wink:
flygt4
Postby Dell'Orto » Sat Sep 15, 2007 6:46 pm
Its definately not suitable, I think the factory recommendation is a 10w40. 15w50 if its higher k's. 25w50 is suitable for dirty old bogan V8's with massive ring clearances
Postby LEV_101 » Sat Sep 15, 2007 7:04 pm
Mmm, Boost wrote:Its definately not suitable, I think the factory recommendation is a 10w40. 15w50 if its higher k's. 25w50 is suitable for dirty old bogan V8's with massive ring clearances
its only done 80000. will there be any problems ?
LEV_101
oil
Postby docTRD » Sun Sep 16, 2007 6:03 pm
yea id agree that oil is a bit too thick for turbo application as a thicker oil doesnt like small clearances and turbos / small bearings. a 10w40 semi syn or a 10w30 penzoil is good stuff. 15w40 is cheaper but id recommend a good 10w40 for all turbo cars.
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby Dell'Orto » Sun Sep 16, 2007 6:09 pm
With too thick an oil you can risk popping seals out. Drain it and replace it with Magnatec or something similar.
Users browsing this forum: Bing [Bot] and 18 guests
