Coilovers question
Coilovers question
Postby Warren » Sun Sep 16, 2007 1:16 pm
Hey,
Just wanting to know which way you turn the lock disc things to lower the car.
My rear ones are already at the bottom of the thread and my front ones are about 15mm from the bottom of the thread. Does this mean that my car is as low as it can basically go? If so, thats fine cos it rides quite nice and doesn't scrape very often at all.
I can't put my front ones to the bottom of the thread otherwise the springs arent captive.
Mr. T says "Don't do school, stay in milk, and drink your drugs"
Warren
Postby d1 mule » Sun Sep 16, 2007 1:36 pm
left raises the car, right lowers it.
from what i understand it sounds like its as high as it can go??
d1 mule
Postby Warren » Sun Sep 16, 2007 1:39 pm
d1 mule wrote:left raises the car, right lowers it.
Thats what I thought. If I were to screw dics up that would compress the springs therefore lower the car right?
Warren
Postby d1 mule » Sun Sep 16, 2007 1:46 pm
is it on the spring or the height adjustment bit?
d1 mule
Postby ChaosAD » Sun Sep 16, 2007 1:48 pm
So theyre reverse thread? I would have thought that left would lover the spring platforms therefore lowering the car :?
ChaosAD
Postby Warren » Sun Sep 16, 2007 1:54 pm
http://www.tein.co.jp/products/basic_wagon.html
I have those coilovers.
B are the discs I'm talking about. Do those need to go up or down to lower the car? I would have thought up to compress the spring therefore lower the car.
Warren
Postby Warren » Sun Sep 16, 2007 1:57 pm
Warren
Postby ChaosAD » Sun Sep 16, 2007 1:58 pm
The link just goes to the homepage. But on most coilovers, the two rings under the springs will lower the car when you lower them
ChaosAD
Postby d1 mule » Sun Sep 16, 2007 2:21 pm
if you loosen "B" (turn left) you will lower the car same as increasing the pre load raises the car. remember when loosening "B" you are loosening your pre-load on the spring effectivly making the spring softer as there is no pre load only the spring rate eg 6kg/mm instead of maybe 6.5 or 7kg/mm with more pre load wound in im not sure how much preload can be dailed in tho.. hope that makes sense
d1 mule
Postby Mr Revhead » Sun Sep 16, 2007 2:43 pm
mule, what the hell are you talking about? :?
warren, winding the nuts up raises the car
winding them down lowers it
Postby Warren » Sun Sep 16, 2007 3:14 pm
Mr Revhead wrote:mule, what the hell are you talking about? :?
Hahaha, yeah thats was a bit confusing. But thanks for your response mule, appreciate it.
Thanks Revhead, thats all I need to know.
So my car is basically as low as it can go, which isn't very low I might add, not that I'm complaining. At least I can go over speed bumps or up driveways without having to ask people to get out of the car or scrape all the time etc hahahaha.
Warren
Postby Mr Revhead » Sun Sep 16, 2007 3:32 pm
not confusing.... just using the wrong terms and adding in some incorrect statements.
"preload" as he put it is just the spring taking up load. its got nothing to do with increasing or decreasing the spring rate.
winding the spring up does not increae the rate. nor does winding it down decrease it. unless your talking about the first little bit where its just taking up the weight of the car. which it should always do. and that is a very very small amout of movement.
Postby BigDon » Sun Sep 16, 2007 5:24 pm
Is that correct if the are progressives though (for arguments sake)?
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby fivebob » Sun Sep 16, 2007 5:52 pm
Preload, does what it says, it preloads the springs. So that the load applied to them must exceed the preload before they move. It does not change the rate of the springs from that point on though.
Provided they are preloaded below the corner weight of the car then it has no effect on the suspension, other than static ride height.
Postby d1 mule » Sun Sep 16, 2007 9:17 pm
oh i see sorry i thought it increased the rate for some reason :oops:
d1 mule
Postby Trls250s » Sun Sep 16, 2007 11:27 pm
When are you going to finish your drum kit warren?
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Warren » Mon Sep 17, 2007 9:22 am
Trls250s wrote:When are you going to finish your drum kit warren?
WTF!?!?!
Is that you Nic? hahaha
Warren
Postby Trls250s » Mon Sep 17, 2007 10:27 am
haha yea man. Now you have to put up with me on the forums too.
When you going to get your cert?
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Mr Revhead » Mon Sep 17, 2007 10:28 am
PM ppl.... if we want to watch a crappy soap we'll watch shortland street :twisted:
Postby Warren » Mon Sep 17, 2007 1:08 pm
Mr Revhead wrote:PM ppl.... if we want to watch a crappy soap we'll watch shortland street :twisted:
lol, I think our crappy soap talk will be a lot better than shortland street. :P
I'm getting a cert tomorrow for the coilovers at Neil Fraser Certz in Beach Haven
Warren
