I have a few problems with my ae86.
Firstly ventilation.. the cabin stinks of fuel. I run a fuel cell that is sealed off from the cabin but the braided lines run through the cabin and into the engine bay. I cant find any leaks in the connections anywhere.. and the tank and pumps etc are all open to the outside anyway.. any ideas on what could be causing this.. the car is fully stripped out with fiberglass doors and im running lexan windows and have no way for fresh air to get into the car so that is one thing I need to setup. Any ideas on the best way to ventilate it? Petrol fumes are heavier than air right? I noticed that the smell is stronger down by the floor.
Second problem is the brakes are shite. And they shouldn’t be. As they are from the r33 skyline. They seem to work ok once I press hard enough but man I need to push hard on the pedal. Brakes are well bled. When im traveling at slow speeds like in traffic I still need to press really hard on brake to get them to work.. luckily I ride my bike lots cause my leg gets pretty tired after driving. It feels like the disks are just slipping through the pads? Could there be something wrong with the booster? Or the pads?
Any help appreciated
