ST165 complete aftermarket spherical bush replacement
Postby sergei » Tue Sep 18, 2007 3:45 pm
Right, I was thinking (after looking at my bosses RS200 suspension) how expensive is to replace all urethane bushes with spherical items on my ST165 (at the back).
I bet that will increase precision of the steering.
I have replaced all old bushes with urethane items and I am not 100% happy how it feels (dud rack ends don't help - pita to do, might do it when I pull the engine out after I blow it up).
Postby NZ_AE86 » Thu Sep 20, 2007 8:18 am
Think of 30-130 buck a hit for Rod ends then fabrication to make them all fit, then cert on top of that. It can be very expensive! Worth doing for the right reasons though.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby sergei » Thu Sep 20, 2007 10:26 am
Well I eventually will need cert anyway, probably will be the thing to do after rollcage.
Postby RunningRich » Thu Sep 20, 2007 10:50 am
I replaced all of my ST165 bushings with uretahne. It was fantastic apart from the two sphereical bearings on each rear hub. Replacing these with urethane left a little too much play. Are these the ones you are referring to?
If so I have the Toyota P/N for them at home, it is not in the parts listing.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby sergei » Thu Sep 20, 2007 11:32 am
RunningRich wrote:I replaced all of my ST165 bushings with uretahne. It was fantastic apart from the two sphereical bearings on each rear hub. Replacing these with urethane left a little too much play. Are these the ones you are referring to?
That is exactly what I have done.
And exactly same problem with spherical bearing replaced with plain urethane bushes results in too much play (although not too bad, been worse with stock bushes).
