no doubt it has been asked before, but searching found nothing.
I know from reading that they are different sizes, I just wondered how much weight difference there was in a stock vs stock situation?
Stealer Of Souls wrote:When weighing them it pays to weight them WITH the clutch cover.I found out that a bluetop flywheel plus cover has approximateky the same mass as the blacktop flywheel and cover. So unless you need the clutch area, there would be no point in using a blacktop flywheel over a bluetop.
