GTT knocking noise from wheel column
Postby magnazan » Wed Sep 19, 2007 10:41 pm
Had a really strange thing happen with the GTT tonight, when pulling out either left or right (Not boosting hard just normal driving) there is a knocking noise that sounds like its coming from just below the steering column. It's the same sort of sound as if my alarm fob was swinging into the column but it's a consistent knocking until i straighten up. It's not super loud but i can hear it. Only does it occasionally as well, haven't tried to replicate it yet (will do tomorrow)
Anyone got any ideas?
magnazan
Postby Mr Revhead » Wed Sep 19, 2007 10:43 pm
can you feel anything with the knock?
Postby magnazan » Thu Sep 20, 2007 7:19 am
Nothing at all, only does it from standing starts as well.
magnazan
Postby barryogen » Thu Sep 20, 2007 9:27 am
exhaust changed at all?
mine taps when I take off hard, brake hard, or turn hard. If I nana it around it doesn't make a sound.
barryogen
2ZZ Guru in training
Postby magnazan » Thu Sep 20, 2007 10:04 am
It's an aftermarket 3 inch exhaust it maybe flexing when i trundle out of a corner. I really need to get a decent jack so i can get under the damn thing.
magnazan
Postby Mr Revhead » Thu Sep 20, 2007 10:24 am
sway bar bush or rear lower arm bush
Postby magnazan » Thu Sep 20, 2007 11:41 am
Is this something i should get looked at ASAP? Got a trip down to Rotorua this weekend.
magnazan
Update
Postby magnazan » Tue Sep 25, 2007 1:10 pm
The dinas in the garage currently getting the work done to fix the knocking noise.
Turns out the front of the car (After the guy test drove it) was spongy and the shocks do need replacing. The rear was tight and no issues (But getting them replaced anyway). All the bushings are fine. There was something bent on the rear at the back of the diff, which was causing the sway bar to knock against it (Don't knot the name of the part).
Hopefully should have it back in a few hours :)
magnazan
Postby gleem » Wed Sep 26, 2007 5:50 pm
i also get a similar knocking noise when driving over bumps or gravel roads, sounds like the seering rack his hitting something as the sounds coming from under my feet any ideas?
gleem
Postby THA SHZ » Thu Sep 27, 2007 4:37 pm
gleem wrote:i also get a similar knocking noise when driving over bumps or gravel roads, sounds like the seering rack his hitting something as the sounds coming from under my feet any ideas?
Sway bar bushes .
THA SHZ
Postby gleem » Thu Sep 27, 2007 6:39 pm
oh any ideas how much these are? will have to flick revhead a pm
gleem
Postby magnazan » Thu Oct 04, 2007 2:48 pm
Did you get your bushes replaced? I'm still getting the same sound but very randomly had it on the way down to hamilton when going through town. Smooth road, low speed and low revs. Still can't figure it out.
magnazan
Postby barryogen » Thu Oct 04, 2007 7:24 pm
THA SHZ wrote:Sway bar bushes .
does driving style wear these faster?
barryogen
Postby gleem » Sun Oct 07, 2007 8:24 pm
magnazan wrote:Did you get your bushes replaced? I'm still getting the same sound but very randomly had it on the way down to hamilton when going through town. Smooth road, low speed and low revs. Still can't figure it out.
is the noise coming from the front or back? it didn't turn out to be my sway bar bushes, the bolt on the rh side of the stearing rack had lost its nut and was wobbling round everywhere that could be the same for you but doesnt sound like it if its coming up on smooth roads
gleem
Postby magnazan » Mon Oct 08, 2007 10:31 am
My noise comes from under the dash/steering column, it's like someone tapping their knuckles on plastic. It's really really random though. When i had my shocks done i asked him to check all the bushes and he said they were fine. :?
magnazan
Users browsing this forum: Google [Bot] and 20 guests
