by frost » Sun Sep 23, 2007 5:04 pm
30mm is not much if the springs are quite sort then they should still be captive with standred shocks, you only really need short stroke if you are going to lower the car alot like i have and need to keep the springs captive,
the set up on my girls daily driven notch is 3inch lower then standred
TRD race 6kg front and 4kg rear
ae86 kyb gas shocks shortened about 3inches F&R (no need for spacer)
40mm RCA's front and soon to have traction brackets on the back,
standred ae86 sway bars
still keeping the springs captive, and rides really well, not much roll and ok over bumps, its still street able and can also be driven hard on the funny track,
my race car is
8kg front and 6.5kg rear
40mm RCA's
really big swap bars,
not really streetable unless you have a really fat arse for padding,
