4agze Igntion Module
Postby gepsk8 » Sat Sep 22, 2007 8:43 pm
hey, search didn't find it.
who can tell me what wire does what?
Black?
Blue?
Yellow?
Grey?
White?
Red?
Brown?
thanks for help
i've seen info somewhere just can't remember where it did
gepsk8
Re: 4agze Igntion Module
Postby Rick » Sun Sep 23, 2007 10:40 am
For a AE101 4AGZE:
1) BLACK - Coil Output no.2
2) BLUE - Coil Output no.1
3) YELLOW - Tachometer drive
4) GREY - Ignition feedback from igniter to stock ECU
5) WHITE - Toggle input
6) PINK - Ignition input
7) TAN - +12V Power
Body of Igniter - GROUND
Postby strx7 » Sun Sep 23, 2007 4:07 pm
isn't it actually an IGNITOR ?, a module controls the advance etc
Postby matt dunn » Sun Sep 23, 2007 4:29 pm
strx7 wrote:isn't it actually an IGNITOR ?, a module controls the advance etc
Yes it is an igniter not a module,
but module's don't control advance either.
A module controls Dwell and coil current.
An igniter is just a high speed relay.
Postby strx7 » Sun Sep 23, 2007 10:34 pm
yeah knew it was something like that. I get SICK of mechanics ringing u asking for an ignition module for such and such a car. It gets sooo annoying
Postby cogent » Mon Dec 01, 2008 9:17 am
Sorry to bump an old thread for a quick question, but I searched and found this and figured its better than starting a new thread.
I am wiring a G1 V3 link into my AE101 4AGZE in a AE82, using the factory GZE dual channel ignitor to run the factory GZE coils.
Can someone confirm what the 'Toggle input' and 'Ignition feedback' are for, and if they are required for the link?
cogent
Postby matt dunn » Mon Dec 01, 2008 9:32 am
cogent wrote:Sorry to bump an old thread for a quick question, but I searched and found this and figured its better than starting a new thread.
Standard 4AGZE igniter is not compatable with that ECU.
Postby cogent » Mon Dec 01, 2008 12:38 pm
sucks. what will I need to buy to run it instead? I will be getting the firmware flashed to V5, and having the correct daughterboard installed to work with the 4agze CAS.
cogent
Postby matt dunn » Mon Dec 01, 2008 3:59 pm
cogent wrote:sucks. what will I need to buy to run it instead? I will be getting the firmware flashed to V5, and having the correct daughterboard installed to work with the 4agze CAS.
Dual channel igniter,
VR4, Evo, or the subaru legacy NA's have good ones up on the firewall too.
Postby cogent » Mon Dec 01, 2008 4:13 pm
Will any dual channel igniter work? Would I be able to buy an MSD one or something?
I've hit up a few people wrecking evos on trademe. i presume I just need the igniter and can use the 4AGZE coils with it?
Sorry if these questions sound dumb, I have NFI on ignition componants and the like. Any help is appreciated :)
cogent
Postby cogent » Tue Dec 02, 2008 11:02 am
Alright, this is what I need, yeah?
http://img155.imageshack.us/img155/5213/dscf9052kc9.jpg
This unit is from an Evo 3.
Cheers.
cogent
Postby matt dunn » Tue Dec 02, 2008 11:36 pm
cogent wrote:Alright, this is what I need, yeah?
Cheers.
yup.
and will need a plug to connect to it or some way of connecting to it.
