limp stalk ....
limp stalk ....
Postby GTCRSHR » Mon Sep 24, 2007 9:29 am
hey guys,
after removing my dashboard on the weekend, i came to put my window wiper stalk back in and it wont stay at its correct position, i cant actually see how it cant work but it doesnt,
is there something special about putting it back in ? or is there something that is suppose to hold it up in the correct position,
it moves free, just doesnt stay in the right place,
any ideas?
Nothing to see here ...
GTCRSHR
Postby GTCRSHR » Wed Sep 26, 2007 9:39 am
any ideas?
GTCRSHR
Postby rwd_mayhem » Wed Sep 26, 2007 10:03 am
tighten the bolt a bit more?
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby GTCRSHR » Wed Sep 26, 2007 2:59 pm
the screws are tightend up as much as possible :!:
GTCRSHR
Postby Mr Revhead » Wed Sep 26, 2007 3:10 pm
make sure its slotted into the right place?
not upside down?
im not sure i follow your explanation
so instead of the stalk having resistance when u say work the indicators, it just flops around
Postby GTCRSHR » Wed Sep 26, 2007 3:44 pm
Mr Revhead wrote:make sure its slotted into the right place?
not upside down?
bingo,
it slides up and down ok, but it is suppose to stay in the UP position = off now if i slide it up it just falls back down no resistance at all but it still makes contact with the contacts :roll: inside
all round the right way etc,
GTCRSHR
Postby Mr Revhead » Wed Sep 26, 2007 3:55 pm
trying to picture in my head how it goes inside there....
has it still got the ball bearing in the end of it?
Postby GTCRSHR » Wed Sep 26, 2007 4:01 pm
Mr Revhead wrote:trying to picture in my head how it goes inside there....
ball bearing ? i wonder if that has flirted off somewhere ?
basically it slides in and there is a hole at the top (closest to stearing wheel) and then the backplate goes in to a grove and a hole which keeps the stalk straight
GTCRSHR
Postby malc » Wed Sep 26, 2007 6:14 pm
viagra?
malc
Postby GTCRSHR » Wed Sep 26, 2007 6:16 pm
Razz wrote:viagra?
no thanks, maybe try giving it to you dad :?: good luck :twisted:
GTCRSHR
Postby celica_tommo » Wed Sep 26, 2007 6:32 pm
yeah, there's usually a ball bearing and a spring which hold the stalk in position... lost mine last time i took at the dash etc off my old AW11
celica_tommo
Postby GTCRSHR » Wed Sep 26, 2007 7:28 pm
celica_tommo wrote:yeah, there's usually a ball bearing and a spring which hold the stalk in position... lost mine last time i took at the dash etc off my old AW11
ahhhh this sounds like whats happend.... ill have to have a scout on the floor see whats happend,
is this the sort of thing i can get at repco supercheap etc ? or does any one have one i can buy!
GTCRSHR
Postby Grrrrrrr! » Wed Sep 26, 2007 7:59 pm
This sounds like a job for.... pinch-a-part ;)
Grrrrrrr!
Postby GTCRSHR » Sat Sep 29, 2007 1:45 pm
awsome found the missing bearing, thanks for your help
all greased up and slides a lot smoother now :!:
GTCRSHR
