The preamble;
So my troubleandstrife and I are off to Whanga for the weekend, have a bit of a race with a couple of stoners in a HR31 through the gorge, when towards the end the torque converter stoped locking up, no good.
After reaching our destination, and a couple of hours, we drove into town, all things returned to normal, good.
A couple of months later, was towing a trailer up the south side of the bombay's, all locked up in third, gave it a shoefull, and off it slipped again, as before, not locking up at all for the remainder of the trip, in either third or fourth.
Now, being handy with the steel if you know what I mean, i figured i'd swap out the transmission for a second hand one. After finding one on trademe, i was all good to go till I learnt that the lockup clutch is in the torque converter, not in the transmission. No good.
So figuring that some profesional help was needed, I took all my bits to Auckland Automatics, where they decided it only needed a service to correct a possible low oil level, and check the fluid for signs of degradation. That done, no sign, still will slip if i boot it.
Now they want me to take it to an electronics chap to see if the ecu is telling it to drop out.
All I want done (although a bigger job, it seems more certain than looking for signs of 'things') is for them to swap my trans out (done 180k) for the other one i have (done supposedly 80K) and overhaul the t/c in the process. then I know the t/c has been re-worked, and expect that will be my fix.
Long winded I know, But has anyone had a similar problem??
