Hey all...
Finally I have Bazdas suspension in the racecar and the alignment has been setup as follows:
Front Camber -2deg, -2deg
Front Castor +2.5 deg , +4deg
Front Toe -0.5mm, -0.5mm
Rear Camber -.75deg, -.75deg
Rear Toe +0.5mm, +0.5mm (was meant to be 0)
Driving around things are all fine (except the steering doesn't auto centre very well), until I take a decent corner hard. After the car has gone around the corner and then back onto the straight, the steering wheel will be like 1/6 out (in the direction just turned from) - for some time. Eventually it will come back to being straight..
Ive checked all the steering joints / rack ends / tie rods, it all seems tight.
Is this just because of the suspension settings I have?
