smallport wont go... no spark
Postby lucasthefallen » Sun Sep 30, 2007 3:28 pm
ok story is, new leads, new plugs, new cap and rotor, plenty of fuel, using all smallport sensors loom and ecu etc. have swapped the ignitor, didnt make a difference.
everything was fine until i did a compression test on the old engine ( same dizzy etc ), now its just no go.
there was a bad oil leak from the dizzy o-ring, is it possible that the internal ring as leaked oil everywhere inside the dizzy stoping it from producing spark?
any ideas? are there any common problems with no spark on the smallports?
does anyone have any testing procedures and specs for checking the dizzy?
does anyone have a dizzy and/or coil that i can borrow to try?
any help will be greaty appreciated.
lucas
021851115
Need Service or Repair work done? send me a PM
lucasthefallen
Postby frost » Sun Sep 30, 2007 4:00 pm
good earth on coil and igniter?
Postby lucasthefallen » Sun Sep 30, 2007 4:46 pm
yea pretty sure the earth is good, checking resistance between coil housing > battery neg, ignitor housing > battery neg, dizzy housing > battery neg, all showed 0 resistance, so thats good earth right.
on the loom, like 4 mm before the plug for the dizzy, 2 of the wires have small openings in the insulation, looks as though they have been like that for a long time.... ?
lucasthefallen
Postby gepsk8 » Sun Sep 30, 2007 5:45 pm
good earth on coil!!!!!!!!!!!!
lol....
gepsk8
Postby gepsk8 » Sun Sep 30, 2007 5:50 pm
i think u should take it to auto sparky mate.
gepsk8
Postby Bling » Sun Sep 30, 2007 6:00 pm
wheres the fun in that? :lol:
avoid them at all costs, as they will sort your wallet out :?
Although this is a bit more complicated that working out why a 4k won't run so maybe if you need it running soon it could be worthwhile
Postby matt dunn » Sun Sep 30, 2007 7:04 pm
So was going ok then you did a compressions test and now it doesn't go?
How did you disable the spark when you cranked it to do the compression test?
or did you just remove the HT lead and not disable the low tension side.
If the spark has no where to go because you have pulled out the HT lead from the coil etc,
the spark can jump internally in the coil and cause a track in it,
which then makes the coil buggered.
My bet would be this is the case with yours.
Postby lucasthefallen » Sun Sep 30, 2007 7:09 pm
matt dunn wrote:So was going ok then you did a compressions test and now it doesn't go?
i pulled the lead straight out of the coil to disbale the spark.
im going to check the resistances on the coil this evening, i check for 12v ealier and that was ok.
thank you for your constructive comment
lucasthefallen
Postby matt dunn » Sun Sep 30, 2007 7:21 pm
You pulled the lead out of the coil, but the coil itself will still have tried to make spark, unless you unplugged the 12v 2 pin plug to it.
Will still test fine with a multi meter, as the fault is not an open circuit or short circuit, It, an internal air gap that will take 12,000 volts to jump.
Postby lucasthefallen » Sun Sep 30, 2007 7:26 pm
ah ok! well on a mission to find a coil then!
is there a chance that it wouldnt have buggered the coil by doing it they way i have?
lucasthefallen
Postby frost » Sun Sep 30, 2007 8:11 pm
haha i just picked up on that :oops:
no wait hang on, the coil bracket needs to be earthed right?
Postby matt dunn » Sun Sep 30, 2007 8:34 pm
lucasthefallen wrote:ah ok! well on a mission to find a coil then!
Yeah,
At a guess it only happens about 25% of the time,
so 75% of the time your safe,
but from what you describe it sounds like it.
Postby lucasthefallen » Mon Oct 01, 2007 8:19 pm
have tryed a new coil, car goes brooom :D :D
thank you for your advice
lucasthefallen
