can anyone confirm - in stupid-mans - terms how to check a car battery for excess drain while the car isn't running. all I know is it has something to do with checking the amps.
but exactly which setting do I use on the multimeter?
what is the ideal result / reading I should get back?
I've been working thru a few problems with a new project car, as soon as the batt is connected the ignition has power etc (with all switches/key etc off). Pretty sure I got it sorted now but want to check to be 100% sure.
-Matt
