matt dunn wrote:From toyota,
Rod Bolts
Head Studs
Engine gasket set, (use a BT one them you get the head stuff,
as the bottom end is all the same anyway)
Pistons and Rings,
bearings if your replacing them.
escortman wrote:i assume u want to run quite high boost if ur gona use 3bar map sensormatt dunn wrote:From toyota,
Rod Bolts
Head Studs
Pistons and Rings,
so wouldnt it be better to use arp rodbolts and trd metal headgaskit?
flygt4 wrote:if you're doing the gearbox get new synchros.it may pay to invest in tracking down the shorter gears that barry is using as 3rd gear is stupid long on the gtz gearboxes.
TRD 0.8mm headgaskets are really good, its just one less thing to worry about.
have you considered fabrication of an inlet collector?
consider your power level and whether you need a wanky clutch/PP now rather than later? allow $500-800 for that
bluemaumau wrote:are you building the engine?
my builder told me that its common for rod caps to distort when pressing in arp rod bolts, hence the need for a crank grind which = oversize bearings, dont buy anything until your engine builder tells you he needs it, as you may need oversize bearings or pistons
bluemaumau wrote:i think its worth it man, i wanted to do it myself, but theres just alot of little sh*t to get right, it would be better to learn to build a engine if it was a 4k or 4age, but a 200kw 4agte is probley not the best idea for your first.
Adoom wrote:LOL!!! 'only' 22psi!!matt dunn wrote: only handles 22 psi.
