4age belt part number???
Postby fx gt » Thu Oct 04, 2007 4:41 pm
i have taken the aircon pump of my 4age and i was wondering if anyone has the part number for the smaller belt i need to use so its just running two wheels.
cherrr
fx gt
Postby slighty_sykotic » Thu Oct 04, 2007 4:50 pm
Wheres the tensior?
And just get a peice of string, tie it around the wheels, take it off and measure.
Then just go to repco/supercheap and buy.
slighty_sykotic
Postby fx gt » Thu Oct 04, 2007 4:52 pm
AHHHHhh forgot bout that
the one down the bottem near the sump yeh?
so i run the belt wiith that to? i thought i could just run it around the two wheels. maby not :P
fx gt
Postby deaf_rattle » Thu Oct 04, 2007 5:10 pm
i just ran the tape measure around the two pulleys and then took the measurement and the old belt into repco and got the one i needed.
im not using anything to tension it so that makes it hard to put on and you will need to replace the belt more often, unless you work out some way of tensioning it.
Postby fx gt » Thu Oct 04, 2007 5:19 pm
deaf_rattle wrote:i just ran the tape measure around the two pulleys and then took the measurement and the old belt into repco and got the one i needed.
ok cheers
but could i run the bottem pully,how long is your belt lasting?
fx gt
Postby deaf_rattle » Thu Oct 04, 2007 5:58 pm
its still goin and i think its about a year and a half since i did the conversion.
just abit noisy on first start up when its cold or wet.
