Ae92typeX wrote:run the codes before you start replacing stuffs.
gepsk8 wrote:change tps, check map sensors got valcum & maybe try swapping it
matt dunn wrote:cam timing?
KinLoud wrote:Cam timing - if the cambelt has lost a couple of teeth it can skip on the crank pulley or a cam wheel and so get out of time.
Ken
Ham
021 408 863
