strx7 wrote:from memory an AE82 corolla has an inline pump and a inline valve which means the same pump does both the front and rear screens.
Stu- wrote:I'd be interested in how your intercooler spray setup goes - I played around with the same ide on my car and it sprays perfectly but the pump lets water run through it and it tends to drip even thou the pump is off.
Adoom wrote:If you can mount the tank lower than the nozzle/sprayer it shouldn't siphon the water and drip. drip. drip. drip. drip.
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
Users browsing this forum: Google [Bot] and 2 guests
