W55 into Ke35
W55 into Ke35
Postby lorolla24 » Tue Oct 09, 2007 12:56 pm
I want to know whitch shifter postion is the best for fitting into my ke35, will be mounted to a 4AGE, and also if there is any mods needed to fit it into the tunnel.
Currently the car has a 4AGE and T50 box.
Going to run Hilux diff aswell.
Ke35 20v turbo - 200kw atw 13psi
13.5@169km
lorolla24
Postby Soarer T » Tue Oct 09, 2007 10:59 pm
my m8 runs W58(mid position of MA61 celica) in his KE20 with 18R, pretty sure will fit into the tunnel but can not remember if have to cut the panel for the shifter.
Soarer T
Postby sprsta » Thu Oct 11, 2007 9:49 pm
had to move the hole for the gear stick back abit in my starlet but was running a 3tgte wich was sitting well back in thr bay had to change the tunnel to get clearance for bell housing
starlet power (or lack there of)
sprsta
Postby method » Thu Oct 11, 2007 11:47 pm
I ran a rear position shifter, sits a lil fowards compared to the T50.
PICS UPDATED DAILY
method
