Pulley Pullers
Pulley Pullers
Postby ollieboy » Tue Oct 09, 2007 9:04 pm
I've got this pulley puller at home, its the hub type but it doesnt seem to be working, it won't fit on my pulley. What I am wondering is are there different sized pullers or am I probably doing it wrong? I'm just guessing how to use it by a few pictures because it doesnt have any instructions.
Ollie
ollieboy
Postby Zak » Tue Oct 09, 2007 9:09 pm
What pully on what? I assuming it's a crank pully, and by the sounds of it you've got the wrong kind of puller.
Zak
Postby ollieboy » Tue Oct 09, 2007 9:12 pm
All I want to know is are there different sized pullers? I have the correct tool for the job, The Toyota book told me :)
ollieboy
Postby thegreatestben » Tue Oct 09, 2007 9:16 pm
If you are doing the crank pulley on an mr2 (you have one right, I'm assuming since you haven't let on.
you want one of these
thegreatestben
Postby ollieboy » Tue Oct 09, 2007 9:24 pm
Yes on the mr2. Thats the tool I have so I must be doing it wrong. Thats what I needed to know.
Thanks man :D
ollieboy
Postby AE82 FXGT » Tue Oct 09, 2007 10:14 pm
tgb.mr2 wrote:If you are doing the crank pulley on an mr2 (you have one right, I'm assuming since you haven't let on.
If you get one from supercheap, it's cheaper and you get more sizes.
And if your going to bring up quality, it hasn't let me down to date, and I've used it a fair bit.
AE82 FXGT
Postby thegreatestben » Tue Oct 09, 2007 10:20 pm
I don't give a shit who makes it.
Just knew they'd have a pic of that type of puller
I used one from work :P
thegreatestben
Postby Ae92typeX » Tue Oct 09, 2007 10:22 pm
how are you trying to do it?
Ae92typeX
Postby ollieboy » Tue Oct 09, 2007 10:26 pm
By screwing the bolts into the holes on the pulley and then screwing the big bolt thing through the middle. I only had a short go at it as I got called into work while I was doing it. Will have another go tomorrow.
ollieboy
