Ae 101 Gtz owners your help needed
Postby Str8gangsta » Tue Oct 16, 2007 1:02 pm
Hey guys,
I have found vacuum hose that is not connected and am going crazy trying to work out were it goes.It is located just below the intake pipe on the throttle body it is the first one down facing the fire wall and i am pretty sure it goes down to the supercharger somewhere i just cant see where.
Does anyone have a vacuum hose diagram or can understand what I'm trying to explain? Your help would be greatly appreciated. Or if someone lives local and wouldn't mind me having looking at theirs that would be great.
Thanks
Harry
Str8gangsta
Postby ollieboy » Tue Oct 16, 2007 1:24 pm
ollieboy
Postby pjay » Tue Oct 16, 2007 1:47 pm
hey mate, a previous owner may have abv modded your engine, is the engine running any different? do you have any guages? may have been replaced with a gauge vacuum tube
pjay
Postby Str8gangsta » Tue Oct 16, 2007 1:52 pm
It is stock standard. I brought it not going. I got it running and it has like next to no boost i'm picking that this hose is why. What is the abv mod i don't know much about it does it increase you boost on standard pulleys?
Thanks
Str8gangsta
Postby pjay » Tue Oct 16, 2007 3:02 pm
Sounds like the map sensor hose. If youre looking at the engine from the front of the car, the map sensor is mounted vertically under, behind and to the right of the intercooler. the hose plugs up under the map sensor so is easy not to see.
Abv mod increases boost on a stock pulley, yes
pjay
Postby Str8gangsta » Tue Oct 16, 2007 3:10 pm
Sweet thanks man, I will have a look after work. :D
whats involved in the abv mod?
Str8gangsta
Postby themaleman » Tue Oct 16, 2007 7:03 pm
[img][img]http://img518.imageshack.us/img518/3654/map4agzevacuummz4.th.jpg[/img]
the hose to the map sensor dosnt come from the throtle body i believe[/img]
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Users browsing this forum: Google [Bot] and 3 guests
