Replacing Front sway bar bushes...How?
Postby Timoz » Fri Oct 19, 2007 7:40 pm
Hi everyone, I just wanting to know how do i replace the front sway bar bushes for an AE111 Superstrut Levin? As i wanted to attend this myself. Cheers
Timoz
Postby Bling » Fri Oct 19, 2007 7:58 pm
do you have replacement bushes?
surely you can just unbolt the old ones and put the new ones in there place?
what have you tried so far if anything?
Postby Timoz » Fri Oct 19, 2007 8:38 pm
i'm going to buy some tomorrow. do i have to seperate the lower ball joint for the hub to replace the bushes?
Timoz
Postby Voyeur » Fri Oct 19, 2007 9:09 pm
Jack front of car up, put stands under, remover wheels, undo link rods, undo sway bar mounts, replace bushes, reassemble in reverse. Very simple, but you need both wheels unloaded.
Voyeur
Postby Timoz » Sat Oct 20, 2007 11:11 am
Cheers, thanks for the help guys
Timoz
Postby Timoz » Fri Oct 26, 2007 3:26 pm
I'm having trouble getting the sways bar bushes from the local suspension shop, does anyone know where i can get the bushes for the superstrut suspension front and rear D-bushes in Auckland? cheers
Timoz
Postby barryogen » Fri Oct 26, 2007 4:17 pm
Flick and email to revhead.
barryogen
2ZZ Guru in training
Postby Bling » Fri Oct 26, 2007 4:58 pm
viewtopic.php?t=44317
how many places did you try? did you try toyoya?
Postby ChaosAD » Fri Oct 26, 2007 5:31 pm
Make sure you use urethane grease. Do the bolts up lightly, then torque up at normal ride height.
ChaosAD
