by edwagon » Mon Oct 22, 2007 5:31 pm
Sometimes they do freeze up extremely tight
You need to be a bit careful about using heat around your hubs, but a bit warmth from the torch on the nut itself will usually make the nut just about fall off, so that might be worth trying.
Otherwise just get in there and split it with a chisel or cut it off.
But as above, you shouldnt need to remove the cv to replace the studs, infact removing that is nfg to you unless you're also going to take the bearing etc to bits which basically means replcaing the bearing....
Just knock the broken studd out with a hammer and then slot the new one in and pull it up tight.......
