Had the engine mounts replaced and its still happening, though it does feel tighter movement, as if the mounts are dampening it. It only happens at low revs when i throttle back on, also sometimes at high revs re engaging the clutch makes the engine rock backwards and forwards in the mounts. What might still be causing that?
I had read about uneven throttle might be something to do with tps/oxy sensor so i did error code check, and it just kept on flashing, does this mean good or bad? I kept watching it till about 140 and then flagged, according to the FAQ, highest number was something like 73.
Also I tested the VVT pulley with the 12v from battery to solenoid, do you also have to run a -12v for it operate properly? And if so, how have people done it, just using some lose wire i had, the 2 wires came to far close for my comfort, don't want to get spectacular sparks everywhere.\
edit: 20v ST 192ks, run 98 ever since it came to CHCH
