shift light in altezza
Postby adam_ae111 » Mon Oct 29, 2007 3:00 pm
hi i have a 2000 sxe10 3sge 6mt altezza and i just brought a adjustable shift light from trade me and i wanted to know a few things.
has anyone got a bracket for one as mine didnt come with one and has anyone installed one of these because i have no idea really if it will even work in my car? http://www.geocities.com/big_m_u_s_t_a_n_g/DSCF2420.JPG
adam_ae111
Postby thegreatestben » Mon Oct 29, 2007 3:26 pm
Well you have three wires there.
Black is Ground
Red is 12v+
Green is Tach signal
You just set it on the back by the looks of things to the correct rpm.
Easy peas.
thegreatestben
Postby adam_ae111 » Mon Oct 29, 2007 3:44 pm
were would the easiest place to get the tacho signal be ? sorry i am a novice when it comes to electronics :oops:
adam_ae111
Postby ollieboy » Mon Oct 29, 2007 5:56 pm
off the coil. Usually the negative side.
ollieboy
Postby Zak » Mon Oct 29, 2007 8:49 pm
They have coil packs, not quite that simple.
Zak
Postby ollieboy » Mon Oct 29, 2007 10:05 pm
Oh didn't realise. Easiest way would be to tap directly into tach wire at back of gauge cluster then.
ollieboy
Postby ollieboy » Mon Oct 29, 2007 10:08 pm
Although on second thoughts, it might be hard if you have never done it before.
ollieboy
Postby Bling » Tue Oct 30, 2007 12:28 am
if you aren't confident enough to do it yourself, IMO just sell it on again, altezza dashes look mint so why spoil it with that ugly thing.
just my opinion tho!
If you don't know when to change gear I think wiring that is the least of your problems :wink: :lol:
Postby frost » Tue Oct 30, 2007 12:34 am
If you don't know when to change gear I think wiring that is the least of your problems Wink Laughing
lol good call,
Postby solitaire » Tue Oct 30, 2007 11:09 am
BZG|Bling wrote:if you aren't confident enough to do it yourself, IMO just sell it on again, altezza dashes look mint so why spoil it with that ugly thing.
+1
AE92, KZJ120, KDJ120
solitaire
