AE92 black 20V - I need more power - any suggestions
Postby glenb20V » Thu Nov 01, 2007 8:54 pm
Hi All. Best to ask other Toyota guru's. I have an AE92 with a black top 20V in it, has a link and K&N intake. I race it regulary on seal in club events, consistantly 2nd - 3rd in class (F*#@ING Honda's). suspension is billstein, brakes are celica disks and mintex pads. it's a good fast car, providing there are lots of corners.
I Need more straight line speed, any suggestions? I am after the best bang for my bucks. Cams? close ratio box? head work? exhaust? has anyone really experimented with a black top like this, without spending shit loads of money?
glenb20V
Postby levinguy » Thu Nov 01, 2007 9:19 pm
aparently theres not too much (without spending alot of money) that can be done to the head as it flows well from factory.
i would go for bigger cams if i were you
levinguy
Postby glenb20V » Thu Nov 01, 2007 9:29 pm
from every thing that I have read, the ports are normally pretty good except for a few dags here and there, but a good five angle valve cut is always a good starter. I was considering cams, but haven't looked at the cost as of yet.
glenb20V
Postby AceSniper » Thu Nov 01, 2007 9:53 pm
close ratio is real real good... but mostly for corners
Id say cams and abit more comp, but if you want to keep reving do the rods
AceSniper
Postby Leon » Thu Nov 01, 2007 10:02 pm
Are you running a LSD? If not, that's going to help you out of the corners.
Other than that, pretty much you're stuck with taking as much weight as possible out of the car, and driving like a homicidal maniac.
Best tyres possible will help too.
Power without spending a shitload ... um ....
Postby glenb20V » Thu Nov 01, 2007 10:10 pm
I ran sticky Kumho tyrs for the Taranaki rally an dthey were fantastic, then ruined them on the track at taupo. LSD is a bit sad now too I think, I'm hoping that fresh oil might fix that.
already driving fairly hard, take a look at you tube, http://www.youtube.com/watch?v=_c4yk0jmibU
mid stage I ran out of talent.
and this was freaky, http://www.youtube.com/watch?v=bjy6Bq65CDM
just got on the gas and found a car in the middle of the road.
glenb20V
Postby Bling » Thu Nov 01, 2007 11:52 pm
man that was a close call in that last vid!!!
Postby Logan » Fri Nov 02, 2007 7:38 am
loose a couple of hundred kg? how much does it weigh? Not very ecomically viable to modify them.
SR Sold. Onto Other Things
Logan
Postby Leon » Fri Nov 02, 2007 8:08 am
Rallysprint looked like fun.
Pucker facter *extreme* for the sprint.
Maybe you can get a stupidly short diff ratio, more punch out of corners. It does look like you've got fairly tall gearing for a sprint car, if the first vid is anything to go by.
Oh, and try cleaning your windscreen before the run :lol: :wink: Since you're washing your screen in the middle of both those videos. :lol:
Postby Santa'sBoostinSleigh » Fri Nov 02, 2007 10:26 am
Hey Glen
im the guy that came and talked to you at Taupo and the Warea sprint and told you i also had a FX blacktop (Garnett with the MR2's mate)
good to see you signed up!
on an off note, how easily and what flavour celica brakes did you use? did it make much difference?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby icy » Fri Nov 02, 2007 1:01 pm
a real nice airbox and feed it with lots of cold air from front
you will never learn how to swear properly untill you learn how to drive
icy
Postby Santa'sBoostinSleigh » Fri Nov 02, 2007 1:12 pm
icy wrote:turbo it 8)
whats the point?!?!
he's racing in club type events and it puts you into a totally different class.
i get sick of people telling me to do this to mine when they know nothing about the class system!
Santa's Mega Sale
Postby 2LTR Rona » Fri Nov 02, 2007 1:27 pm
Lose the gay V stickers first :P
Its Blair, yes the very same Blair who crewed for ya in Taranaki Tarmac Rally :P not that we had to do much :lol:
Losing weight where possible would be my first point of call. Your front strut brace its rather large and steel isnt it? Small weight savings could be gained there.
Others have removed sound deadening from inside the car, this saves a little also.
Have you had your final tune with the Link or still running it on what you were before? There might be gains there.
Other than those then its time to open the chq book as gaining power with a N/A don't come cheap.
2002 Altezza, 1974 KE25
2LTR Rona
Postby Mr Revhead » Fri Nov 02, 2007 1:54 pm
with out opening up the engine and doing stuff theres stuff all you can do.
i would recommend a rebuild with silver top rods!
Postby AceSniper » Fri Nov 02, 2007 6:13 pm
pull the head... get some "rally" cams and springs do sumthen to adjust the pulleys, skim the head .4-.6mm + TRD heady, push pistons out the top an put silvertop rods in...
adds up quick but that sort of combo should get you going abit quicker, what gearbox are you using? try a c56 and throw your lsd in
AceSniper
Wow small world
Postby glenb20V » Fri Nov 02, 2007 9:00 pm
Hi Blair and Garnett, good to hear from you guys.
Garnett was the Black MR2 I was behind beforde the other one lost it, roughly did the same times, MR2 a little faster I think. Blair was the good bugger that said yes to crewing for someone he didn't even really know for a rally.
I priced up CAMS today from kelfords, yikes, the wife wants a new deck first.
Diff is a standard LSD for a black top. for those that want to know. I am going to get rid of the glass and inside doors etc but it is exoensive for the good stuff.
1040Kg in full rally trim and spare wheel with half tank of gas, no pilots though.
Going to get back to gravel next week, just been in the shed dropping the suspension out.
Everyone should check this out. http://www.youtube.com/watch?v=5LH2wjORSHo
one of the guys in our club made it and it is bloody awsome. (well I think so any way)
Mr RevHead. why silver top rods?????
Cheers guys, have a good one.
EVO 3 rally car
3.0T Surf tow wagon
AE82 FX-GT Paddock bash car
AE101 rolla, shopping cart (wifes car)
glenb20V
Postby glenb20V » Fri Nov 02, 2007 9:06 pm
oh yeah Blair, AKA (2LTR Rona), what oil did you say to put in the gearbox? The oil is looking like metalic slush now so I need to change it.
Also havn't tunned it yet, need some sponsored expertise and dyno time. looking at cams too.
EVO 3 rally car
3.0T Surf tow wagon
glenb20V
Postby matt dunn » Fri Nov 02, 2007 10:09 pm
glenb20V wrote:I ran sticky Kumho tyrs for the Taranaki rally an dthey were fantastic, then ruined them on the track at taupo.
What version of the Khumo's?
V700, V70A, C03?
Different ones are good for different purposes,
and with some of them have had a real bad run.
Postby gepsk8 » Fri Nov 02, 2007 10:33 pm
blacktop, rods cant handle over reving, hard time, etc
i would talk to company called psp plastics and make the window plastic there should save good weight there, u dont need lenso plastic on sides windows (i can get it if u want know few ppl there) wouldn't touch the front and rear windows as u need lenso plastic for them also scratchs easy,hard to fit and make a good seal.
O272754663
gepsk8
Postby AceSniper » Fri Nov 02, 2007 11:35 pm
$$$$ for cams builds fast as you need all the gear to follow... springs, gears
Silvertop rods should be on top of the list for the style of driving... to save you from blowing the engine to bits.
AceSniper
