AE101 Front Strut Removal
Postby big-ben-007 » Mon Nov 05, 2007 2:10 pm
Right I am now lowering the front of my car this week and im having a basic problem
The front strut is annoying and I cant get it out
There is the bolt that goes into the top part of the hub and the other bolt that goes into the lower arm?, that is off to the side of the strut
Both bolts have been removed along with the top nuts, but I cant seem to get the strut free, I cant lift it up to get the thread from the hub out because the thread at the lower arm is holding it still, and I cant get the thread from the lower arm out because the thread from the hub is holding it, so I cant move it moving side to side
I assume I'm missing something really simple here, or I need to unbolt something else.
Also the car is a AE101 Levin S/S
To regain some dignity this is really the first Toyota I've ever worked on 8O
Now: 1956 Dodge Pick-up, 1988 EP71 Starlet
Before: 1985 Ford Telstar, 1989 Mazda 323, 1991 Ford Telstar s/w, 1991 Nissan Pulsar GTI, 1991 R32 Nissan Skyline RB20DE, 1991 AE101 Levin GTZ Superstrut Version
"Oh man, I just shot Marvin in the face" - Vincent Vega
big-ben-007
Postby Voyeur » Mon Nov 05, 2007 2:40 pm
I have the whole procedure step by step on the camera at home i will, post in the projects tonight?? But you need to "break" the top balljoint, and then use a bar to slide the bottom arm off, the bottom link. Both the balljoint and the bottom link can be real tight.
2005 vz ss commodore
Voyeur
Postby 20v FX-GT » Mon Nov 05, 2007 3:13 pm
Voyeur wrote:I have the whole procedure step by step on the camera at home i will, post in the projects tonight?? But you need to "break" the top balljoint, and then use a bar to slide the bottom arm off, the bottom link. Both the balljoint and the bottom link can be real tight.
Sorry for the thread hijack here but my girlfriend's GTZ (also superstrut) had a new lower arm fitted on Friday in order to pass a wof. Prior to this it didn't make any noises over bumps but now it does. Could it be that they did some damage to the top balljoint in removing it from the arm? Visibly everything looks OK but there is definitely a problem. It is partcularly noticable when turning.
Thanks
1981 & 1982 MK1 VW Golf GTI 8v
1997 AE111 Toyota Trueno 6 Speed
My profile l AE101 FX GT Site l AE111 BZ Site l
20v FX-GT
Postby Voyeur » Mon Nov 05, 2007 3:27 pm
Was it the lower arm or the number 8 link. They should not have had to pop the top balljoint to replace either, and did they use genuine parts or crap aftermarket parts. I dont know about noise's, maybe someone with more experiance could help. Perhaps descripe type of sound and approx location (top of strut, hub, etc)
Voyeur
Postby big-ben-007 » Mon Nov 05, 2007 3:28 pm
Please post those photos :D , I did everything you said (i think) and anything I pull/pull is tight, so I dont want to damage anything whist trying to get it off because I'm doing the wrong thing :?
big-ben-007
Postby 20v FX-GT » Mon Nov 05, 2007 4:16 pm
Voyeur wrote:Was it the lower arm or the number 8 link. They should not have had to pop the top balljoint to replace either, and did they use genuine parts or crap aftermarket parts. I dont know about noise's, maybe someone with more experiance could help. Perhaps descripe type of sound and approx location (top of strut, hub, etc)
Crap after market parts I'm picking. Part number is 48066 in the pic on this page http://www.geocities.com/bz20v/superstrut.htm
Which part do you mean by number 8 link?
From your previous post I thought you mean that you have to pop 43350 upwards and outwards first in order to undo the strut from the lower arm at 48066. Is that what you meant?
20v FX-GT
Postby Voyeur » Mon Nov 05, 2007 4:17 pm
No worries, might be easier to do it at work in the morning, (only got dial up at home :evil:
Voyeur
Postby big-ben-007 » Mon Nov 05, 2007 4:32 pm
got the bottom thread/ball joint off
The top one right above the CV joint is a pain, because I can't use the same tool I used to get the lower part off, also managed to get a fat lip from a wayward steel bar :lol:
any hints from anyone?? :D
big-ben-007
Postby big-ben-007 » Mon Nov 05, 2007 8:04 pm
got the strut out :D
Nothing like hitting a bracket with a hammer as hard as you can to get things out :lol:
big-ben-007
