Aw11 dash warning lights going.
Postby ollieboy » Mon Nov 12, 2007 2:54 pm
I haven't been driving my mr2 for a while because I was fixing bits and pieces on it. When I started it today the cooling fan, cat converter and charge lights won't go off. I don't think I have driven it since I replaced the cambelt and waterpump so I probably forgot to do something after that which caused this but I'm not sure.
Do I have to reset anything to get the lights to go off? Or is the problem probably a bit worse than that?
Ollie
ollieboy
Postby Mr Revhead » Mon Nov 12, 2007 3:27 pm
whats ya volt gauge doing?
Postby ollieboy » Mon Nov 12, 2007 3:30 pm
It sits at just over half way when idling
ollieboy
Postby sergei » Mon Nov 12, 2007 3:38 pm
most likely fried alternator. If so battery will not last very long.
Postby ollieboy » Mon Nov 12, 2007 3:40 pm
Would that cause the cooling fan and cat light to come on too?
ollieboy
Postby sergei » Mon Nov 12, 2007 3:51 pm
Yes, when alternator goes the cat light comes on with battery light. Not sure about cooling fan light never seen one.
Postby Mr Revhead » Mon Nov 12, 2007 3:52 pm
he doesnt mean cooling fan light, he means cooling fan :wink:
Postby ollieboy » Mon Nov 12, 2007 4:01 pm
Ahh, it appears you are right- I went and tested the battery with multimeter and it stayed at the same on and off.
Thats gutting.
ollieboy
Postby sergei » Mon Nov 12, 2007 4:03 pm
Oh I see, then you should look into loose grounds, as the cooling fan circuit is separate from lights. The fan comes on when the thermoswitch opens (thus losing connection with ground)
Postby ollieboy » Mon Nov 12, 2007 4:13 pm
Oh, yeah I was meaning cooling fan light. Like this:Image
Is there a fuse for the alternator that I can check? Or would it just be a dead alternator?
ollieboy
Postby sergei » Mon Nov 12, 2007 4:27 pm
There is a fuse for alternator, in different cars it has called different, eg ALT.
Look for 7.5A-15A fuse in the engine bay fusebox.
Postby Mr Revhead » Mon Nov 12, 2007 4:46 pm
:lol: i dont remember my AW having one of those lights!
Postby ollieboy » Mon Nov 12, 2007 5:00 pm
Yeah? I guess its a kind of odd light now I think about it- I've never seen one before I got the AW.
I found a bown fuse in the engine compartment and changed it, it didn't make a difference so thats quite annoying.
ollieboy
Postby mr30%jr » Mon Nov 12, 2007 6:22 pm
it just warns when the engine bay temp is high and fan hasnt come on for whateva reason
BGB says only drive at 60ks lol :lol:
there cool be various reasons usually fried alternator but the regulator plug could be out or the alternator feed could be loose
mr30%jr
Postby ollieboy » Mon Nov 12, 2007 8:08 pm
I'm kind of thinking it must be a loose connection- it wouldn't just stop working after not being used would it?
ollieboy
Postby Mr Revhead » Mon Nov 12, 2007 8:09 pm
seeing as you have just been playing aound in that area... it does seem likely you stuffed something up :P
Postby ollieboy » Mon Nov 12, 2007 8:11 pm
More than likely :lol: I'll have another look tomorrow and see if anything is loose.
ollieboy
Postby matt dunn » Mon Nov 12, 2007 10:37 pm
Dont discount the fact that the alt could be stuffed.
Unplug the 3 pin plug at the alt and test the 3 pins,
With the key on and it unplugged you should get 12V at all the pins with a multimeter,
or
power at two with a test light and a faint glow on the other.
Matt
Postby ollieboy » Mon Nov 12, 2007 10:39 pm
Is that with the key on but the car not actually running?
ollieboy
Postby matt dunn » Mon Nov 12, 2007 10:51 pm
ollieboy wrote:Is that with the key on but the car not actually running?
Yes.
