is there any way of checking what sort of spring an external wastegate is running, other than fitting it to a vehicle and checking what boost it reaches?
-matt
Wastegate Testing
Wastegate testing must be done with the exhaust system initially cold.
Raise the vehicle on jack stand.
Disconnect the wastegate actuating line for the wastegate and connect a pressure pump.
Start the engine an allow it to idle. The exhaust line to the wastegate should heat up after a short period of time. However, if the wastegate is closed and not leaking by, the bypass line out of the wastegate will be cold.
Using the pressure pump slowly apply pressure to the wastegate while feeling the bypass line.
NOTE
Never apply more that approximately 14.5 psi (1 bar) pressure to the wastegate diaphragm during testing. The factory shop manual says to apply 0.6 bar (8.7 psi) of pressure to the wastegate to get it to open. However, the pressures listed below are based on actual numbers from two different 944 Turbo owners who independently tested their wastegates and came up with the same results.
At a pressure of approximately 4 psi (0.2 bar), the wastegate should start to open as indicated by a temperature increase in the wastegate bypass line. At a pressure of approximately 7 psi (4.8 bar) the wastegate should be fully open. Of course, you won't be able to see the exact position of the wastegate if you are testing it in place. However, you can check actual position of the valve during a bench test.
When the pressure is suddenly removed, the wastegate should close as indicated by an audible click.
matt dunn wrote:If it's a genuine Tial you can tell by the colour and size of the spring.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
