AE86ID wrote:im in the welly region where is the best place to score one and how easy is the swap ?
Get one from revhead they are way cheaper than at supercheap and repco. It's quite an easy swap, just follow the bottom radiator hose to where it meets the block, the thermostat housing is quite a unique shape so it stands out. There should be two bolts on there. Undo them and pop off the housing then pry out the thermostat with a screwdriver but be careful not to gouge out the aluminium on the housing. Then just put your new thermostat in, making sure the bleeder hole is at the highest point in the hole. Put everything back together and you are done.
Its sometimes easier to remove the airbox if you still have one and also there might be a plug on the thermostat for the fan, make sure you take that off so you don't damage the wiring and remember to put it back on after.
