I got my Power FC from Japan and tried to install it.
Serial number on Power FC is "PFC SXE10 020-0361"
Part number is "414-T006" (which is correct for 98 altezza Non turbo)
Serial number on the FC commander is "FCC3 020-24295"
Car will not start.
When plugged in and when ignition set to ON:
-Radiator Fans power up
-Fuel pump starts
-Engine check light on (should be off)
-FC Commander does NOT power up (should be on)
-Injectors 1 and 3 are on
-Cylinders 1 and 3 full completely with fuel
-Car will not start due to hydrolic lock in cylinders 1 and 3.
-Car starts and runs normally with stock ECU plugged in once the fuel has drained into the sump.
So here is my problem...
Is the ECU broken?
Is there something i'm doing wrong?
Is there addition wiring that i need to do for this ECU to run that i dont know about?
I'm going to open it up and see if there is any visually damaged components.
Well, time to get drunk tonight and drown my sorrows!!!
Cheers, Mike
