ae100g brake swap prop valve?
Postby soopachargen » Tue Nov 20, 2007 6:05 pm
i have an ae100g corolla wagon and have a disc brake rear setup for it... i have been unable to find a disc proportioning valve, the wrecker suggested that they use the same proportioning valve from drum to discs, is this correct? and what size master cylinder does the ae101 gtz run??
When in doubt, down and out.
soopachargen
Postby soopachargen » Tue Nov 27, 2007 6:24 pm
does anybody know?
soopachargen
Postby KinLoud » Tue Nov 27, 2007 9:37 pm
Disk brake calipers needs higher pressure to get the same braking force.
A drum brake proportion valve will give a lower pressure to the rear when compared to a disk proportion valve.
You will have no problem with rear brake locking.
However - your overall braking will be better if you can find a disk proportion valve.
Hope this helps
Ken
Ham
021 408 863
Postby soopachargen » Wed Nov 28, 2007 7:45 am
thanks ken, that was exactly what i was looking for
soopachargen
