1JZ and 2JZ injectors... ???
Postby trd-drifting » Tue Nov 27, 2007 7:01 pm
I am sorry if this has been covered but just after some help.
Ok some people I have spoken thought 1JZ and 2JZ injectors are interchangeable but by have pulling my stock 1JZ injectors out and comparing them with the 2jz injectors. They appear to be a lot different and I would say they are not interchangeable but I am no mechanic and far from it so please correct me if I am wrong.
The Photos show 2 different sealing points and where the fuel flows through are in 2 different locations. The 1JZ injector is the yellow one :)
Any opinions????? or things that I am missing....
Josh
trd-drifting
Postby postfach » Tue Nov 27, 2007 9:13 pm
was the 2jz those injectors came out of vvti? or perhaps non-turbo? i had a set of 2jz injectors and they were externally identical to my 1jz ones except colour of plug and the holes in the bottom. oh, and they came with different o rings, but the 1jz ones fit on.
postfach
Postby trd-drifting » Tue Nov 27, 2007 9:27 pm
Um i got told they were 2jzgte injectors, I will find out what they are from but for some reason i think they were out of a 1998 but can't confirm. As the picture shows they are compltely different does this make them out of a 2jzgte vvti
trd-drifting
Postby trd-drifting » Tue Nov 27, 2007 9:30 pm
They are from a 1998 2jzgte
trd-drifting
Postby postfach » Tue Nov 27, 2007 11:04 pm
Pretty sure the 98 supras would have been vvti, someone on here can probably confirm this (A friend of mine had a 98 RZ, which was definitely vvti).
If you really want some, look for a set out of an earlier 2JZ-GTE, non vvti.
I really should find out where my set have gone.
postfach
Postby matt dunn » Tue Nov 27, 2007 11:34 pm
What are they supposed to be rated at?
The USA spec are 550's, but jap spec are 440 or 450 aren't they?
Postby Silent Knight » Wed Nov 28, 2007 9:00 am
Yep, the USA is 550cc and JDM is 440cc. JDM is straight swap but the USA one I think is a different impedence...
Silent Knight
Postby trd-drifting » Wed Nov 28, 2007 4:55 pm
I believe they are to be 440cc since that solves that question would there be any1 that would like to swap i have a fuel rail they can have to some 2jzgte non vvti injectors for these ones which i believe as postfach said to be vvti injectors
Josh
trd-drifting
Postby matt dunn » Wed Nov 28, 2007 10:38 pm
Silent Knight wrote:Yep, the USA is 550cc and JDM is 440cc. JDM is straight swap but the USA one I think is a different impedence...
yes, i remeber we got caught with that actually.
Postby Mr Revhead » Wed Nov 28, 2007 10:48 pm
Postby trd-drifting » Thu Nov 29, 2007 3:01 pm
Cheers again for evrything guys
trd-drifting
