4age smallport a/c removal question
Postby lucasthefallen » Tue Nov 27, 2007 8:25 pm
ok is in an 1991 ae92 fxgt smallport blah blah. i want to remove the a/c pump purely because its packing up and i dont want it to seize and break the belt. now, question how do i go about this and what parts do i need???? ( for those who dont know its running off the same belt as the waterpump )
Need Service or Repair work done? send me a PM
lucasthefallen
Postby docTRD » Wed Nov 28, 2007 2:55 pm
hey man on my 1990 GT sedan i removed all my air con bits bar the ac pump but yea just a shorter belt and 14mm and 17mm bolts holding it on im pretty sure, relatively straightforward.
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby ChaosAD » Wed Nov 28, 2007 5:17 pm
I had an fx with ps and no a/c. It had a bracket with an idler wheel on it instead.
ChaosAD
Postby gepsk8 » Wed Nov 28, 2007 5:55 pm
this has been covered, few time now, please search
running off the same belt as the waterpump, u sure?
normal it runs a/c p/s off crank, have seen weird thing tho
ur got to find ae82 p/s pump or slot ur 1 as ae82 do, run idler pulley like my car does standard nz new gti with no a/c, and some1 just unbolt p/s pump pull the belt on but couldn't tension if if it got loose.
O272754663
gepsk8
Postby lucasthefallen » Sun Dec 02, 2007 12:32 pm
sorry your right, runs the same belt as the p/s. so i could just moddify the p/s pump to pivet so i can tension a smaller belt?
lucasthefallen
