Soarer uzz30 Vs jzz30 parts?
Postby M.B.M.1 » Wed Nov 28, 2007 6:14 pm
Does any 1 no whats interchangeable and whats not from the rear subframe of a soarer My mate slid the arse end of his jzz30 into a curb and bent the botom arm going to the hub (the arm that the swaybar mounts 2) and replaced it with a uzz30 1 ,and it now has positive camber the only thing i can think of is that the arm is shorter?
M.B.M.1
Postby Mr.Phreak » Wed Nov 28, 2007 6:23 pm
Holy quad post batman
The arms are the same, did he align it in the same place he took it out?? or what else did he bend when he slid into the curb??
Mr.Phreak
Postby M.B.M.1 » Wed Nov 28, 2007 6:33 pm
He replaced the 2 botom steel arms (non adjusable) and the cast arm im talkin about wich has the adjustable lobe on it and that turned out now (was even worse adjusted in) were the other side is adjusted in ,thats why i thort they mite be different. I have a complete jzz30 subframe here so i was just going 2 give him mine.
M.B.M.1
Postby Mr.Phreak » Wed Nov 28, 2007 6:39 pm
Both of the suspension arms should be adjustable, guessing the other arm you're talking about is the strut rod?
Mr.Phreak
Postby M.B.M.1 » Wed Nov 28, 2007 6:48 pm
Yeah sory just looked alittle closer at mine. Everything looks fine on his it just has very bad positive camber and its got me stumped.
M.B.M.1
