T28 turbo on 4age
T28 turbo on 4age
Postby l1ttle_d3vil » Fri Nov 30, 2007 5:36 pm
Anyone got any advice on running a T28 turbo on a 4age? I know the T25 is a small-ish turbo, good for fast spool but doesn't have much top end. How different is the T28?
Would one with the following specs be good for around 200kw atw on a stock aw11 4agze block? I can't really interpret any of this stuff so any help is appreciated!
Also, is the T28 the same flange as a T3?
cheers.
Std Trim T28 Turbine
0.49 (Pitch of turbine)
Turbine housing - 431876 - 70D
46.75 Inducer
43.12 Exducer
Postby Crucible » Sat Dec 01, 2007 12:15 am
i think T25 T28 are the same flange, T3 is differant.
Crucible
Real Life Mechanic
Postby evil_si » Sat Dec 01, 2007 1:55 am
different flange to t3 t25 and t28 are a fair bit smaller
evil_si
Postby escortman » Sat Dec 01, 2007 8:04 am
t28 is a t2 flange
4x4 toyota blizzard offroader
escortman
Postby l1ttle_d3vil » Sat Dec 01, 2007 12:08 pm
right so the flange is definitely different ... i think? :wink:
what can I expect from one of these power wise?
Postby Crucible » Sat Dec 01, 2007 10:01 pm
If you buy a small Turbo youll want bigger, if you have a Big Turbo, youll probley want someting a little smaller, i bet yah!!
its a hard choice, no such thing as a perfect turbo.
Go big, brag to your mates, mines bigger than yours lol 8)
Crucible
Real Life Mechanic
Postby l1ttle_d3vil » Sun Dec 02, 2007 10:47 am
True-No-Turbo wrote:If you buy a small Turbo youll want bigger, if you have a Big Turbo, youll probley want someting a little smaller, i bet yah!!
yeah, originally i went n/a, now I'm building a turbo 4age. once this is built, i'll want to go turbo 7age :roll:
if I can get something near 200kw atw I'll be happy, with any turbo aslong as it isn't excessively laggy. one of these turbos has come up for a decent price but i'm just a bit hesitent in buying it because i'm not totally sure of its capability.
Postby flygt4 » Sun Dec 02, 2007 12:16 pm
i reckon a vf24 like i use would be a good compromise. usable boost in the mid 3000rpm, 201psi by early 4000rpm, and capable of 220kw atw. i got my one brand new for 1100. not bad for a decent sziewd ballbearing turbo.
flygt4
Postby rollaholic » Sun Dec 02, 2007 12:52 pm
rawr, 201 psi! would have expected a bit more power though :P
Postby flygt4 » Sun Dec 02, 2007 1:36 pm
lol 21psi
flygt4
Postby Zyros » Sun Dec 02, 2007 4:00 pm
t28 is what im using on mine, i think it will go mint :)
Mate has one on his GTX, spools early, and goes all the way till you almost have to change gears.
Zyros
Postby flygt4 » Sun Dec 02, 2007 7:17 pm
matt dunn actually had a t28 running for a while, was doing ~200kw atw
flygt4
Postby matt dunn » Sun Dec 02, 2007 8:20 pm
flygt4 wrote:matt dunn actually had a t28 running for a while, was doing ~200kw atw
Yeah had two versions of them on my car,
was a Silvia T28 for a while, then had a GTiR wheel fitted to the exh side and a larger wheel on the intake too.
was around the 200kw at 18psi on a stardard silvertop with GZE pistons.
Users browsing this forum: No registered users and 30 guests
