Wiring diagram needed for power windows (altezza or other ?)
Postby TWSTD » Fri Dec 07, 2007 3:10 pm
Afternoon folks.
Does anyone have a wiring diagram for the powered wing mirrors on an altezza? Its quote likely the same as other toyotas too... There are 7 wires going to each mirror and I need to know what they all do:
Black x 2
Blue
Green
Red
Brown
Purple.
Thanks! :-)
Click here!
TWSTD
Postby TWSTD » Mon Dec 10, 2007 4:44 pm
anyone?
Click here!
TWSTD
Postby postfach » Mon Dec 10, 2007 6:09 pm
i didn't even test this link, but try this, supposedly has an IS300 wiring diagram, should have what you're after in there
postfach
Postby TWSTD » Mon Dec 10, 2007 8:06 pm
ummmm which link? LOL
Click here!
TWSTD
Postby postfach » Mon Dec 10, 2007 11:22 pm
hahaha, yes, im awesome, hang on i'll find it again
http://s93555471.onlinehome.us/is300/is300.zip
postfach
Postby TWSTD » Tue Dec 11, 2007 6:45 am
dead link im afraid.
Click here!
TWSTD
Postby GTCRSHR » Tue Dec 11, 2007 9:30 am
can you not put a multimeter on the end of them to see which way when you move the button has power ? thats how i figured out which goes where on my m3 mirrors :?:
Nothing to see here ...
GTCRSHR
Postby TWSTD » Tue Dec 11, 2007 10:44 am
Yeah i guess i could - assuming that each wire has a discrete signal relating to a particular movement (which they may not).
Click here!
TWSTD
Postby Zak » Tue Dec 11, 2007 8:27 pm
I have from the IS200/300 electrical diagrams...
Left Side (Right Side)
P-B (P-B) = Motor +
P-G (LB-Y) = Motor Vertical
P-L (LB-R) = Motor Horizontal
LG (LG) = MR - seams to go to some diodes then to a motor then to the demister?
LG-R (LG-R)= MF - goes to the demister
They seem to be different colours to yours, I will try get some more info for you tommorw.
What are you trying to do with the wiring?
Zak
Postby TWSTD » Wed Dec 12, 2007 6:15 am
Thanks for that - ill look over it this weekend and do some testing. Have installed aftermarket powered mirrors that have far fewer wiring connections!
Click here!
TWSTD
