So I'll start with my exhaust system. As it stands I have a 2 1/4" - 2 1/2" standard exhaust system on my car. Pitstop last year in there wisdom installed a 1 1/2" section to replace a section that was cracked. I noticed that this was causing problems and decided at some point I would replace it ... but... as things happen I never got round to it.
My problem now is that I have a cracked first muffler. In the inlet and the outlet - makes it sound like it isn't connected. I believe this has probably been caused by the small pipe after the muffler. So I now need to replace it and that section of pipe at the same time.
Now with all the background information that I have provided. Would I be able to remove this muffler and change it for a straight exhaust through to my muffler on the rear of my car? I have read the LTSA guidelines for the exhaust system and it states I must have a resonator or silencer, so I assume my rear muffler will be sufficient.
I don't want a loud droning exhaust as I find that is more for wank factor than anything.
Will this be ok for warrants etc. Is it likely to sound drony and annoying?
That should explain what it says above. Oh and I already know I have the mad mspaint skills, so thanks.
