black top
black top
Postby matt9ball » Wed Dec 12, 2007 11:43 am
There is a black top for sale on trademe close to me...at has a comp test of 150 125 140 125
the guy said when it left japan it had a tapping noise coming from under the rocker cover???
How much do you think this is worth??and would it be worth my while to buy??is engine ok....comp test seems bad!!
Have a ae85 i was wanting to drop it in if the engine was ok or a easy fix.
Thanks
matt9ball
Postby d1 mule » Wed Dec 12, 2007 12:21 pm
i think the generl rule of thumb is +- 5% on compression tests so id say its a no go un less you can get it for like $100. [/list]
d1 mule
Postby AceSniper » Wed Dec 12, 2007 4:20 pm
would need rebuild, if your lucky its something you can reseat/fit with out to much cost
AceSniper
Postby matt9ball » Wed Dec 12, 2007 9:32 pm
ok thanks guys let it go it went on trademe for over 400....
matt9ball
