20V BT 1-2 PSI BOOST
Postby Voyeur » Fri Dec 14, 2007 2:58 pm
Basically after peoples thoughts, at 1-2 psi boost, would a standard map black top need any mods, injectors, controller, fuel pressure, or pump. etc etc.
I have read on wheels jamaica, of one guy running 5psi with no problems, but i would worry about fueling at that level
2005 vz ss commodore
Voyeur
Postby AceSniper » Fri Dec 14, 2007 3:37 pm
worry about throwing a rod or cracking a piston, cheaper in the long run/more reward todo it right
AceSniper
Postby Bling » Fri Dec 14, 2007 3:38 pm
1-2psi, is that even worth getting out of bed for? :lol: :lol:
if you going to boost it do it properly with the associated engine mods (all found on this forum)
I personally wouldn't waste my time getting it turbo'd to run 1-2 psi
Postby Voyeur » Fri Dec 14, 2007 4:05 pm
I never said turbo, that is later down the track, and yes i am concerned with throwing rods, but what i am asking is, is the map able to register positive pressure, will the injectors and fuel system cope, etc etc, with no mods, ie standard computer.
Voyeur
Postby Bling » Fri Dec 14, 2007 4:15 pm
ah my bad :oops:
so you're thinking of using a supercharger to make 1-2psi?
Postby Voyeur » Fri Dec 14, 2007 4:22 pm
Nah,
I have some free time on the dyno, and i would like to prove or disprove once and for all, electric type intake charges. I have a tornado POS, and a more promising in-line 3 inch barrel fan, which spins at 24000rpm moves a lot of air and is capable of up to 3psi push restriction.
I just have too much time :lol:
Voyeur
Postby matt dunn » Sat Dec 15, 2007 6:37 pm
No the sensor is not capable of reading positive pressure,
but at 1 or 2 psi the car would run fine on the stock map for sopme dyno runs etc etc.
would be good to see your results.
