Towbar Installation
Towbar Installation
Postby BZG Wagon » Sun Dec 16, 2007 12:24 am
I have a '97 Caldina GTT.
How hard would it be to install a towbar? I have been told that they generally line up to some pre-drilled holes under the body and it simply gets bolted to the car.
Does anyone know if it is that straight forward?
Wiring up a loom shouldn't be a problem.
BZG Wagon
Postby Bling » Sun Dec 16, 2007 8:37 am
as long as the towbar is built for the car, then yes it will just bolt up
Postby KinLoud » Sun Dec 16, 2007 8:57 am
Some toyotas (and other makes) have a plug in the loom all set up to connect to trailer wiring. In our NZ new camry wagon this plug is in the left side of the spare wheel area behind the left rear wheel arch. Just plug the trailer wiring plug and loom you can buy from toyota in and then wire it into the trailer socket.
Ken
Ham
021 408 863
Postby BZG Wagon » Sun Dec 16, 2007 10:39 pm
Cool - sounds easy enough.
By chance, would these look like the holes I'd bolt it up to:
Ken; I had a good look around but couldn't find the loom. I'll give Toyota a call tomorrow & find out if they know more about it otherwise its not a biggie for me to wire it off my lights.
BZG Wagon
Postby Bling » Mon Dec 17, 2007 12:19 am
wheres the towbar pic? the holes used by the towbar can possibly vary, so its not too easy to guess if it will bolt to those holes
Postby Mr Revhead » Mon Dec 17, 2007 8:20 am
being an import, there is a good chance you will need to drill some holes.
Postby cedwards » Mon Dec 17, 2007 12:23 pm
Those are the holes mine has used.
cedwards
Postby BZG Wagon » Thu Dec 20, 2007 9:05 pm
cedwards wrote:Those are the holes mine has used.
The place I went said they'd only charged me $45 for installation ($250 for the bar + $45 installation = $295 all up). So I figured I'd just get them to do it and not worry about the hassle.
Interestingly they didn't use those holes - they drilled two others near them which go all the way into the boot. there are 6 bolts in the boot which were all drilled.
Looked like there was a bit more to it than I was expected..
Just need to connect the loom Saturday morning & then that's it.
BZG Wagon
