jza70 1jz question
jza70 1jz question
Postby MRDRFT » Tue Dec 18, 2007 9:12 pm
my supra is a 92 jza70.
just want to no why the cooling fan is hydrolic?(sorry about spelling)
it has its own little coller and pump and fluid bottle?is it easy to take it out or is it not worth the hassel?im not worried about the fan as such, just the big long cooler for it as it is in the way of geting my intercooler in there.will the fan work allright without the cooler?
thanks
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby Py7h0n » Wed Dec 19, 2007 7:20 am
It really needs the cooler!! If it is getting in the way your not installing your intercooler properly.
If you want to remove it you have to do it properly which means replacing the whole pump with a std non hydro pump.
Py7h0n
Postby MrOizo » Wed Dec 19, 2007 3:04 pm
Py7h0n wrote:It really needs the cooler!! If it is getting in the way your not installing your intercooler properly.
yeah thats what you should do if you have to.. i used a 2JZGTE water pump in mine. the cooler lines are up the top and are above / behind the bumper iron arent they? :o
MrOizo
Toyspeed Legend
Postby MRDRFT » Wed Dec 19, 2007 10:28 pm
the little cooler for it sits infrount of factory intercooler.i might just move the cooler then.
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby d1 mule » Wed Dec 19, 2007 10:51 pm
change to electric fans??
d1 mule
Postby MRDRFT » Thu Dec 20, 2007 5:22 pm
looks to be too much work as it has a pump and stuff on the motor and the pump not belt driven.
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby postfach » Thu Dec 20, 2007 5:32 pm
yeah, you'll need to replace that pump at some stage anyway, since its the waterpump, and when you go to get a new one, and they tell you its $1500, you probably won't be wanting one anymore. lucky for us there is an alternative, which requires changing to electric fans, but easily works out cheaper, by miles.
postfach
Postby MRDRFT » Thu Dec 20, 2007 6:30 pm
my fan is hydrolic.it ant on the water pump.
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby postfach » Thu Dec 20, 2007 6:46 pm
There are lines going to the waterpump. Your waterpump has the 1 bolt pulley, the waterpump for JZ powered cars without the hydraulic fan are 4 bolt pulley.
postfach
Postby MRDRFT » Thu Dec 20, 2007 7:07 pm
so my fan is powered buy water?im confused haha
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby postfach » Thu Dec 20, 2007 7:24 pm
Haha, nah it's not powered by water, there's an attachment on the waterpump that drives the hydraulic fluid.
postfach
Postby MRDRFT » Thu Dec 20, 2007 7:26 pm
oh i got ya!
sweet thanks man,i mite just change the cooler so i can get my intercooler in there.
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby Si » Fri Dec 21, 2007 9:38 pm
i swear my hydro fan didnt have a cooler
Current: , '96 SubaruImpreza
Si
Postby sergei » Fri Dec 21, 2007 10:30 pm
I saw this system on a Windom, and thought: what a stupid system, why not just have electric fan - more efficient, cheaper, less stress on water pump...
Sometimes it seems that engineers who come up with stuff like that, are doing just for fun....
Postby Si » Sat Dec 22, 2007 6:35 pm
From what I gather the hydro ones were used when they ran out of room for a belt driven setup. From my readings I gather they push out a considerable amount of air over a belt or electric system
Si
Postby Mr.Phreak » Sat Dec 22, 2007 8:41 pm
Not to mention they're infinitely variable in speed, I'll take my Hydraulic fan over an electric or clutched fan any day.
Mr.Phreak
Postby Zak » Sat Dec 22, 2007 9:24 pm
The pumps have come down in price a bit now too, around $700 or lower from what I remember.
Zak
