Info about 1G-GTE to 1JZ-GTE Engine Swap GA70 Supra
Postby Sideros » Fri Dec 21, 2007 8:52 pm
Hey, Well i'm considering this swap - makes so much sense! What info is available about engine mount points and differences? I've got a rear sump 1JZ-GTE which shouldn't cause any problems with the GA70 crossmember - not as far as I can tell anyway. Just wanna know if anyone knows of an adaptor or anything for 1G to 1J mounts... Or any other useful info for that matter! Chur :)
Sideros
Signwriter
Postby MrOizo » Fri Dec 21, 2007 9:32 pm
you have a late (89.5+) supra dont you?
all you'll need are the alloy mounts from the block.
Have a look at this site: http://turbosupras.com/pages/en/pages/t ... mation.htm
have some pics on the differences on the subframes.
MrOizo
Toyspeed Legend
Postby Sideros » Fri Dec 21, 2007 9:35 pm
Ah yes! But unfortunatly not - My car is a 1992 however has a 1986 crossmember in it! Still I should be able to sort something out with that, Cheers boe!
Sideros
Signwriter
Users browsing this forum: Bing [Bot], Google [Bot] and 27 guests
